The Sensor Intel Series is created in partnership with Efflux, who maintains a globally distributed network of sensors from which we derive attack telemetry.
Additional insights and contributions provided by the F5 Threat Campaigns team.
Introduction
For May’s vulnerability analysis, we examine the top ten CVEs most targeted, highlighting notable shifts and ongoing trends in exploitation activity. Additionally, we provide analysis of a year's worth of targeted CVE traffic through the lens of primary Common Weakness Enumerations (CWEs) and the OWASP Top Ten categories.
Top CVEs for May 2025
In May, the CVE-2017-9841 PHPUnit RCE holds steady as the most targeted vulnerability with over 54,000 instances (see Table 1). CVE-2020-8958 Guangzhou RCE saw a significant jump in targeting. CVE-2020-8958 AvertX Enumeration saw a jump in targeting also, although in keeping with its recent fluctuation. CVE-2024-3721 TBK DVR Injection also saw a proportionally large increase in targeting, re-entering the top 10 in May although still below levels of targeting of fall of 2024. CVE-2024-3721 was the only top 10 CVE to see any significant change to EPSS, jumping a full 0.2. We speculate that the EPSS jump is in related to leading indicators from Mirai activity recently reported on by Kaspersky.1 We saw no changes in Known Exploited Vulnerabilities (KEV) in the top ten CVEs for May.
CVE RANK CVE ID CVE NAME MAY TRAFFIC CVSS EPSS KEV
1 (--) CVE-2017-9841 PHPUnit eval-stdin.php RCE 54633 (-3986) 9.8 0.94406 (--) Y
2 (up 2) CVE-2020-8958 Guangzhou ONU Command Injection RCE 5157 (+2859) 7.2 0.86759 (+0.0129) N
3 (up 5) CVE-2020-11625 AvertX Camera Username Enumeration 3237 (+1662) 5.3 0.00309 (+0.0011) N
4 (up 6) CVE-2023-1389 TP-Link Archer AX21 Command Injection RCE 3112 (+1778) 8.8 0.94022 (-0.0013) Y
5 (down 3) CVE-2019-9082 ThinkPHP PHP Injection RCE 2766 (-229) 8.8 0.94141 (-0.0001) Y
6 (down 3) CVE-2022-24847 GeoServer JNDI Lookup RCE 2367 (+35) 7.2 0.00154 (+0.0002) N
7 (down 2) CVE-2022-42475 FortiOS FortiProxy SSL-VPN Heap Overflow RCE 2166 (-33) 9.8 0.93065 (+0.0003) Y
8 (down 2) CVE-2024-4577 Apache PHP-CGI Argument Injection RCE 1909 (-228) 9.8 0.94376 (--) Y
9 (down 2) CVE-2022-22947 Spring Cloud Gateway Actuator Code Injection RCE 1610 (-211) 10 0.94474 (--) Y
10 (up 1) CVE-2024-3721 TBK DVR OS Command Injection 1532 (+565) 6.3 0.50993 (+0.2231) N
Table 1: Top 10 CVEs for May 2025. CVSS scores are v3.1. All data is as of 2025-05-31.
Common Weakness Enumerations (CWEs) Analysis
F5 Labs analyzed the last twelve months of CVE traffic through the lens of CWEs. We present an F5 Labs Top CWEs ranking as well as an F5 Labs OWASP Top Ten CWEs breakdown.
Mapping CVEs to CWEs
How CVEs map to CWEs, as well as how CWEs inter-relate, is somewhat involved and beyond the scope of this article. We spare you the details, suffice to say that we’ve simplified and cleaned up the mapping from CVE to a single primary CWE for each of the top 25 CVEs of the last twelve months (see Table 2). CWEs often have verbose names, so for brevity we’ll use shortened names for the rest of this article. CWE names are inherently specialized and can be quiet inaccessible, so we’ve included a contextualized refresher on each of them in the following section.
CVE CVE Name Primary CWE CWE Name CWE Short Name
CVE-2017-9841 PHPUnit eval-stdin.php RCE CWE-94 Improper Control of Generation of Code ('Code Injection') Code Injection
CVE-2023-1389 TP-Link Archer AX21 Command Injection RCE CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2022-24847 GeoServer JNDI Lookup RCE CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2022-22947 Spring Cloud Gateway Actuator Code Injection RCE CWE-94 Improper Control of Generation of Code ('Code Injection') Code Injection
CVE-2020-8958 Guangzhou ONU Command Injection RCE CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2020-11625 AvertX Camera Username Enumeration CWE-203 Observable Discrepancy Observable Discrepancy
CVE-2022-42475 FortiOS FortiProxy SSL-VPN Heap Overflow RCE CWE-787 Out-of-bounds Write Out-of-bounds Write
CVE-2019-9082 ThinkPHP PHP Injection RCE CWE-94 Improper Control of Generation of Code ('Code Injection') Code Injection
CVE-2024-4577 Apache PHP-CGI Argument Injection RCE CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2024-3721 TBK DVR OS Command Injection CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2022-47945 ThinkPHP Lang Parameter LFI RCE CWE-22 Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal') Path Traversal
CVE-2018-0296 Cisco ASA Web Interface Directory Traversal DoS CWE-22 Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal') Path Traversal
CVE-2021-28481 Microsoft Exchange Server RCE CWE-94 Improper Control of Generation of Code ('Code Injection') Code Injection
CVE-2021-26855 Microsoft Exchange Server RCE CWE-918 Server-Side Request Forgery (SSRF) Server-Side Request Forgery (SSRF)
CVE-2020-0618 Microsoft SQL Server Reporting Services RCE CWE-502 Deserialization of Untrusted Data Deserialization of Untrusted Data
CVE-2018-10561 Dasan GPON Authentication Bypass CWE-284 Improper Access Control Improper Access Control
CVE-2024-3273 D-Link NAS HTTP GET Command Injection CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2015-2051 D-Link DIR-645 HNAP Command Execution CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2023-23752 Joomla Webservice Endpoint Access Control CWE-284 Improper Access Control Improper Access Control
CVE-2021-44228 Log4Shell CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2014-2908 Siemens SIMATIC S7-1200 XSS CWE-79 Improper Neutralization of Input During Web Page Generation ('Cross-site Scripting') Cross-site Scripting
CVE-2021-26086 Atlassian Jira Path Traversal CWE-22 Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal') Path Traversal
CVE-2017-18368 ZyXEL P660HN-T1A Remote Log Command Injection CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2021-40539 Zoho ADSelfService Plus REST API Auth Bypass RCE CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection') Command Injection
CVE-2019-18935 Telerik RadAsyncUpload .NET Deserialization RCE CWE-502 Deserialization of Untrusted Data Deserialization of Untrusted Data
Table 2: The top 25 CVEs by observed activity over a 12-month period, and their corresponding primary CWE mappings.
CWE Refresher
CWE numbering, much like CVE numbering, is a necessary evil. It is very beneficial to be able to unambiguously refer to CWEs, but then CWE identifiers alone carry no semantic meaning for the reader. Furthermore, readers will be forgiven for not being intimately familiar with the technical underpinnings of attacks involving each CWE. The following list is a reminder of the essential aspects of each CWE in the context of CVEs exploited over HTTP requests. For additional details, consult the mitre.org repository footnote links as many have robust diagrams and explanatory text to further contextualize each CWE.
These are the CWEs we’ll be referring to in the article, listed here in order of significance:
  • CWE-94: Code Injection2 - An attacker crafts an HTTP request with malicious content that is directly evaluated or executed by the server resulting in Remote Code Execution.
  • CWE-77: Command Injection3 - An attacker supplies input in an HTTP request that is unsafely concatenated into a system command resulting in Remote Code Execution.
  • CWE-203: Observable Discrepancy4 - An attacker manipulates HTTP requests to trigger subtle differences in server responses (e.g. error messages, response timing, etc), inferring sensitive internal state or existence of resources.
  • CWE-787: Out-of-bounds Write5 - An attacker sends crafted HTTP data (typically a field that is too long) that causes the application to write outside the bounds of a memory buffer, corrupting memory and potentially enabling Remote Code Execution.
  • CWE-22: Path Traversal6 - An attacker includes directory traversal sequences (i.e. “../” and encoded variations such as “..%2F”) to access files outside the intended directory, commonly exposing, and sometimes modifying, sensitive files.
  • CWE-918: Server-Side Request Forgery (SSRF)7 - An attacker submits a crafted URL in an HTTP request, causing the server to make HTTP requests that bypass firewall and request routing controls to interact with internal HTTP services.
  • CWE-502: Deserialization of Untrusted Data8 - An attacker delivers malicious serialized objects in an HTTP payload, which, when deserialized by the server, result in logic manipulation or Remote Code Execution.
  • CWE-284: Improper Access Control9 - An attacker sends HTTP requests that exploit missing or weak access control checks to access sensitive data or perform sensitive actions.
  • CWE-79: Cross-site Scripting10 - An attacker injects malicious scripts into HTTP requests that are stored by the server and later executed in the victim’s browser, enabling session hijacking, credential theft, or arbitrary actions as the victim’s user.
F5 Labs Top CWEs
We have ranked CWEs by their total annual traffic (see Table 3). Furthermore, the individual CVEs and their annual traffic are listed for convenience of traceability. CWE-94 Code Injection ranks highest due to the outsized influence of CVE-2017-9841. CWE-77 Command Injection comes in second and represents the greatest diversity of CVEs in the F5 Labs Top CWEs. The numbers of CVEs as well as associated CVE traffic volume fall off from the third rank onwards, and yet contain a number of counterintuitive surprises we explore here.
Offensive practitioners would be forgiven for calling in to question the low rankings of CWE-22 Path Traversal, and CWE-284 Improper Access Control. The reason for this is obscured behind the fact that the CWEs here are ranked by the primary CWE we have mapped CVEs to. Regarding CWE-284, arguably many of the CVEs listed here were missing proper access control, but only as secondary CWE root causes. CWE-22 Path Traversal ranking lower, however, is best explained in terms of attacker motivation. While path traversal bugs are commonplace, they are rarely as impactful for attackers to exploit, which in turn means other more impactful exploits see significantly higher levels of attention and therefor correspondingly higher CWE traffic.
Blue teams might find the low ranking of CWE-203 Observable Discrepancy to be anomalous as techniques like user enumeration and default credential reuse are commonplace. Again, the primary motivation we see in evidence in F5 Labs CVE traffic is Remote Code Execution (RCE). So even when default credentials are leveraged as part of an exploit chain, we have still picked the more critical root cause to be the primary CWE attribution in this data set (e.g. with the post-auth CVE-2020-8958 Guangzhou ONU Command Injection RCE).
The final ranking surprise we anticipate readers may have is for the relative high ranking of CWE-787 Out-of-bounds Write. There are two parts to the explanation here. The first half of the explanation is statistical: with such a small sample size of CVEs and many fine grained CWE categorizations it becomes unsurprising to arrive at CWEs with only a single associated CVE. The second half of the explanation is due to the high level of visibility and impact of exploitation of SSL-VPN devices. We suspect that these two factors coincided in this case to elevate CWE-787 Out-of-bounds Write surprisingly high in the rankings.
Primary CWE CWE Short Name CWE Total Annual Traffic CVE Annual Traffic CVE CVE Name
CWE-94 Code Injection 375343 325529 CVE-2017-9841 PHPUnit eval-stdin.php RCE
27193 CVE-2022-22947 Spring Cloud Gateway Actuator Code Injection RCE
16262 CVE-2019-9082 ThinkPHP PHP Injection RCE
6359 CVE-2021-28481 Microsoft Exchange Server RCE
CWE-77 Command Injection 242034 154687 CVE-2023-1389 TP-Link Archer AX21 Command Injection RCE
32036 CVE-2022-24847 GeoServer JNDI Lookup RCE
21613 CVE-2020-8958 Guangzhou ONU Command Injection RCE
11757 CVE-2024-4577 Apache PHP-CGI Argument Injection RCE
9049 CVE-2024-3721 TBK DVR OS Command Injection
4167 CVE-2024-3273 D-Link NAS HTTP GET Command Injection
3355 CVE-2015-2051 D-Link DIR-645 HNAP Command Execution
2269 CVE-2021-44228 Log4Shell
1747 CVE-2017-18368 ZyXEL P660HN-T1A Remote Log Command Injection
1354 CVE-2021-40539 Zoho ADSelfService Plus REST API Auth Bypass RCE
CWE-203 Observable Discrepancy 21444 21444 CVE-2020-11625 AvertX Camera Username Enumeration
CWE-787 Out-of-bounds Write 19613 19613 CVE-2022-42475 FortiOS FortiProxy SSL-VPN Heap Overflow RCE
CWE-22 Path Traversal 16076 7915 CVE-2022-47945 ThinkPHP Lang Parameter LFI RCE
6396 CVE-2018-0296 Cisco ASA Web Interface Directory Traversal DoS
1765 CVE-2021-26086 Atlassian Jira Path Traversal
CWE-284 Improper Access Control 7648 4684 CVE-2018-10561 Dasan GPON Authentication Bypass
2964 CVE-2023-23752 Joomla Webservice Endpoint Access Control
CWE-502 Deserialization of Untrusted Data 6093 4862 CVE-2020-0618 Microsoft SQL Server Reporting Services RCE
1231 CVE-2019-18935 Telerik RadAsyncUpload .NET Deserialization RCE
CWE-918 Server-Side Request Forgery (SSRF) 5296 5296 CVE-2021-26855 Microsoft Exchange Server RCE
CWE-79 Cross-site Scripting 2253 2253 CVE-2014-2908 Siemens SIMATIC S7-1200 XSS
Table 3: F5 Labs Top CWEs for a 12-month period, with total annual traffic and associated CVEs.
We have totaled the traffic each OWASP Top Ten category received over the last twelve months (see Table 4). We have done this by following the mapping from CVE to primary CWE to OWASP category, and propagated the CVE traffic through to the resulting OWASP category. The resulting data shows a remarkably unbalanced alignment between OWASP Top Ten categories and observed CVE traffic. A03:2021 – Injection is the clear leader in observed CVE traffic. This makes a lot of intuitive sense as CVE exploitation inherently skews in favor of Remote Code Execution outcomes. Counter-intuitively A01:2021 - Broken Access Control is relatively underrepresented. Echoing our analysis from previously, arguably many of the CVEs listed here were missing proper access control, but only as secondary CWE root causes. F5 Labs attribution from CVE to OWASP category is dependent on our determination of the single primary CWE, which were often variations of injection CWEs.
Many OWASP categories have no attributed CVE traffic. The primary explanation we have here is due to the lens through which OWASP Top Ten, necessarily, views security. The OWASP Top Ten serves to educate software engineers and support their defending security teams. Therefor the OWASP categorization reflects the holistic security needs of developing software, which does not necessarily correlate with CVEs that see mass exploitation. For example, OWASP Top Ten categories will be very valuable for framing contextualized penetration tests, but much less relevant at explaining the intersection between exploitation outcomes and availability of vulnerable devices and software. Concretely, A02:2021 - Cryptographic Failures would show up in an assumed breach penetration test with a finding such as “Passwords unencrypted in database backups”, whereas such a deployment-specific vulnerability is unlikely to show up in mass exploitation of a published CVE.
Of final note for the F5 Labs OWASP Top Ten CWEs, we list two CVEs that have no corresponding OWASP category. With CVE-2020-11625, CWE-203 Observable Discrepancy did not fit cleanly into any OWASP category. With CVE-2022-42475, buffer overflow bugs have not featured in the OWASP Top Ten since the early days in 2004 (as A5 Buffer Overflow11).
OWASP Category OWASP Category Total Annual Requests CWE CWE Short Name CWE Total Annual Requests CVE Annual Requests CVE CVE Name
A01:2021 - Broken Access Control 23724 CWE-22 Path Traversal 16076 7915 CVE-2022-47945 ThinkPHP Lang Parameter LFI RCE
A02:2021 - Cryptographic Failures 0 N/A N/A N/A N/A N/A N/A
A03:2021 - Injection 619630 CWE-94 Code Injection 375343 325529 CVE-2017-9841 PHPUnit eval-stdin.php RCE
A04:2021 - Insecure Design 0 N/A N/A N/A N/A N/A N/A
A05:2021 - Security Misconfiguration 0 N/A N/A N/A N/A N/A N/A
A06:2021 - Vulnerable and Outdated Components 0 N/A N/A N/A N/A N/A N/A
A07:2021 - Identification and Authentication Failures 0 N/A N/A N/A N/A N/A N/A
A08:2021 - Software and Data Integrity Failures 6093 CWE-502 Deserialization of Untrusted Data 6093 4862 CVE-2020-0618 Microsoft SQL Server Reporting Services RCE
A08:2021 - Software and Data Integrity Failures 0 N/A N/A N/A N/A N/A N/A
A09:2021 - Security Logging and Monitoring Failures 0 N/A N/A N/A N/A N/A N/A
A10:2021 - Server-Side Request Forgery (SSRF) 5296 CWE-918 Server-Side Request Forgery (SSRF) 5296 5296 CVE-2021-26855 Microsoft Exchange Server RCE
N/A N/A CWE-203 Observable Discrepancy 21444 21444 CVE-2020-11625 AvertX Camera Username Enumeration
Table 4: The OWASP Top Ten categories with their associated CWEs and observed CVEs in activity over the past 12-months.
Long Term Targeting Trends
CVE-2017-9841 (PHPUnit eval-stdin.php RCE) maintains high levels of targeting (see Figure 1). No other CVE in recent months comes close to CVE-2017-9841’s level of activity. CVE-2019-9082 (ThinkPHP PHP Injection RCE) maintained consistent levels of activity and in doing so was surpassed by growth in all the remaining CVEs in the top five for May: CVE-2020-8958 (Guangzhou ONU Command Injection RCE), CVE-2020-11625 (AvertX Camera Username Enumeration), and CVE-2023-1389 (TP-Link Archer AX21 Command Injection RCE).
CVE-2017-9841 maintains significantly higher activity than all other CVEs observed. CVE-2019-9082 activity stays constant.
Figure 1: 12-month bump plot of the top 5 CVEs. CVE-2017-9841 maintains significantly higher activity than all other CVEs observed. CVE-2019-9082 activity stays constant.
Long Term Trends
CVE-2020-8958 (Guangzhou ONU Command Injection RCE, top right) is the most significant trend to watch in May, maintaining near exponential targeting growth levels on prior months for 3 months running now (see Figure 2 – readers are reminded that the y-axis scale is logarithmic). CVE-2023-1389 (TP-Link Archer AX21 Command Injection RCE, top left) has broken with its downward trend and may be seeing revived interest. CVE-2024-3721 (TBK DVR OS Command Injection, right) may be on the cusp of returning to prior peaks of targeting with almost a 60% increase in May.
CVE-2020-8958 has established a steep upward trend. CVE-2023-1389 has broken its downward trend. CVE-2024-3721 may be establishing an upward trend.
Figure 2: Evolution of vulnerability targeting in the last 12-months, shown using a logarithmic scale for ease of comparison. CVE-2020-8958 has established a steep upward trend. CVE-2023-1389 has broken its downward trend. CVE-2024-3721 may be establishing an upward trend.
Conclusion
Observed CVE targeting in May 2025 held consistent with recent trending, with a slight uptick in overall activity. We reported significant increases in activity CVE-2020-8958 (Guangzhou ONU Command Injection) and CVE-2024-3721 (TBK DVR OS Command Injection) and speculated that the latter is likely due to a Mirai variant. Analysis of twelve months of CVE targeting attributed to Common Weakness Enumeration (CWE) and OWASP Top Ten categories indicate a continued bias by attackers towards injection vulnerabilities leading to Remote Code Execution outcomes, specifically CWE-94 (Code Injection) and CWE-77 (Command Injection). There were some surprises to our CWE and OWASP Top Ten analysis which we addressed in their respective sections.
Recommendations
Technical
Preventative
  • Scan your environment for vulnerabilities aggressively.
  • Patch high-priority vulnerabilities (defined however suits you) as soon as feasible.
  • Engage a DDoS mitigation service to prevent the impact of DDoS on your organization.
Technical
Detective
  • Use a WAF or similar tool to detect and stop web exploits.
  • Monitor anomalous outbound traffic to detect devices in your environment that are participating in DDoS attacks.
Authors & Contributors
Merlyn Albery-Speyer (Author)
Principal Cybersecurity Threat Researcher, F5
F5 Labs Top CWEs & OWASP Top Ten Analysis | F5 Labs
