In the past few years, organizations have reported a growing number of incidents involving groups of attackers trying to damage commercial and institutional web applications by exhausting their resources through distributed denial-of-service (DDoS) attacks. Attacker groups understand that preserving application availability is a high priority for most organizations because availability influences application revenue, and therefore any reduction in the quality of service can reduce revenue as well as damage the organization's reputation.
Application-level DDoS attacks are popular specifically because it's a challenge to completely protect against them. By design, the application level of the network is generic in nature; each application has unique characteristics, but the interfaces and mechanisms used to deliver those applications are similar. As a result, the application layer is vulnerable to a wide range of threats, including relatively unsophisticated attacks. For instance, analysis of recent DDoS attacks on a major credit card company involved in the 2009 WikiLeaks incident indicated that when the company's website first experienced downtime, 940 computers were participating in the attack, which used brute-force HTTP traffic to the application.1This case shows how easily even a simple attack can bring a web application to its knees. With more sophisticated DDoS tools, attackers can identify specific vulnerabilities in applications and their delivery methods, enabling them to use less bandwidth and more distributed resources to exhaust application resources across the network.
A good example of how easily public vulnerabilities can be found and exploited was shown by the recently discovered vulnerability of web servers running a certain combination of PHP5, Java, and ASP.NET. Specially crafted HTTP requests targeted towards this very specific platform combination can result in collisions of the web server's hashing function when unique requests return non-unique and overlapping responses. An attacker could send many "hash busting” requests at the same time to successfully create a denial of service event on the web server, starving legitimate resources.
Fortunately, by focusing on how users interact with applications in real-time and how those applications are delivered over the network, organizations can predict how attackers and attacks will evolve. When looking at the threat from a protective point of view, it becomes possible for application and network administrators to work together to detect and protect against DDoS threats.
The appropriate Application Delivery Controller (ADC) can serve an invaluable role. F5 BIG-IP Application Security Manager (ASM), which resides between applications and users, can detect and protect against an attack in real-time by:
By controlling access, implementing challenge/response and anomaly detection engines, and applying the ability to understand application behavior, BIG-IP ASM defends against malicious connections and keeps attackers from overwhelming applications.
Figure 1: F5 BIG-IP ASM is a web application firewall that detects and mitigates the threat of application DDoS attacks based on the ability to understand the application layer and its behavior.
Recent application-level DDoS incidents show that such an attack can be described as a mass of HTTP requests to the web application from as many sources as possible. Before DDoS was the attack du jour, the standard, single-point denial-of-service (DoS) attack was a tried and true staple of the attacker community. Unlike its distributed cousin, a standard DoS attack uses a single source that sends as many requests as possible to affect application availability, where a DDoS attack is mounted from multiple, geographically distributed locations as it tries to bypass traditional protection methods.
From a security standpoint, this difference between DoS and DDoS attacks dictates the way a security filter can detect and mitigate the attack. A security filter can easily detect an abnormal rate of HTTP requests sent from one source, as happens in a traditional DoS attack. Once detected, the attack can be mitigated easily by blocking access from the single source.
While the DoS scenario seems trivial from a protective point of view because it's so easy to detect and mitigate, the DDoS is much more complex, since it includes a multi-source attack with each source sending many HTTP requests. These attacks are usually conducted by ranks of 'zombie' PCs: devices infected by malware and controlled remotely by an anonymous attacker, often without the machine's owner having any knowledge that an attack is underway. To detect this type of attack, DDoS protection policies need to study how the attacked application is legitimately used. This can only be done by learning how the application is accessed over time, including all the characteristics of valid traffic. These characteristics typically include:
The detection of these traffic characteristics should be based on anomaly detection, or in other words, changes in the application behavior. For example, if the access rate of an application's search page is typically 500 transactions per second and suddenly that rate jumps to 5000 transactions per second, it is usually safe to assume that the search page is being abused and possibly attacked. Depending on the source locations of each of those requests, the application may be subject to DDoS attack. In this example, the security filter should not monitor the source of attack, but rather the resource under attack.
BIG-IP ASM detects such attacks by learning how the application is normally accessed. Depending on configuration, BIG-IP ASM generally accomplishes this by collecting the following information:
BIG-IP ASM will detect an attack when there is a change in the way an application is being accessed compared to the normative values it has already learned.
After detecting that an application is under DDoS attack, the next step in defense is to determine who is attacking the application—or at least, what information about the attacker(s) can be discerned. By definition, a DDoS attack is not mounted by one source that needs to be blocked, but rather by many. In the above example of unusual search page requests, there might be multiple users trying to perform searches on the application. Some of these sources of traffic will be valid users, while others are participants in the attack, and the challenge is to differentiate between the legitimate and the illegitimate searches.
The best way to differentiate is to challenge users by distinguishing between normal users who work with browsers and malicious automatic tools that send requests directly to the application. One example for such a challenge is the CAPTCHA authentication test, which is used on many application login pages and attempts to repel brute-force attacks by requiring the user to respond to a random or personal challenge.
Another example of an effective challenge, and one used by BIG-IP ASM, is the injection of JavaScript to the user. Only clients who use a browser pass this challenge, while malicious automated tools fail it. As a result, BIG-IP ASM can selectively pinpoint and block those automated tools.
Detection and attacker identification are not always decisive, of course. The complexity of the scenario affects the accuracy of detection efforts, and challenging detection tasks may result in false positives. In addition, failure to respond to a security challenge does not necessarily equate to an attack. For example, a challenge can fail to receive a response as a result of the users' browser limitations or configurations. Nonetheless, security measures with the ability to discern information about potential attackers and pose one or more challenges to suspicious users can more effectively detect and thus mitigate threats.
As noted, application delivery is often a primary business goal and may be an organization's dominant—or only—customer interaction. In such cases, dropping application users' transactions is unacceptable, even when suspicious users fail to respond to a security challenge. Instead, efforts to mitigate DDoS attacks should apply these principles:
If an attack occurs, mitigate the attack's effects on the application. Preserve application availability so it remains intact for other users.
One mitigation option that conforms to these principles is to increase the overall availability of an attacked resource by lowering the rate at which suspicious sources can access the application, thus maintaining application availability and preventing the DDoS attack at the same time. The benefits of this approach are that:
Using this approach, the worst case scenario becomes a false positive that slows user connectivity to the application but does not prevent user service, thereby maintaining availability for legitimate users. In actual attacks, the application is protected as well.
During a potential attack, several mitigation options are available:
Administrators can manage the balance that BIG-IP ASM provides between application protection and availability by setting policies to influence how aggressively suspicious connections should be dropped.
BIG-IP ASM uses a unique, bi-directional approach to detecting DDoS attacks and identifying attacker information, thereby preserving quality of service and mitigating the effects of an attack at the same time. Because BIG-IP ASM sits between users and applications, it can maintain awareness of both to:
BIG-IP ASM also keeps IT administrators apprised of both normal and potentially abnormal application activity through operational dashboards and reporting. In addition to the management dashboard, which routinely displays operational data such as connections, throughput, and availability, BIG-IP ASM provides specific reports on DoS and DDoS incidents. Administrators gain an easy reference to detailed views of detected anomalies, the mitigation response including dropped connections, and the suspicious IP addresses involved. With this data, organizations can understand the frequency and level of DoS and DDoS attacks against their networks, as well as the effects those attacks may have had on availability, so management decisions can be made with confidence.
Web applications are both crucial to the operations and customer service of many organizations and particularly vulnerable to the DDoS attacks occurring with such prevalence today. Detecting attack is the first step to mitigating it and preserving application availability. When trying to determine whether an application is under a DDoS attack, any change in the behavioral characteristics of the application should be taken under consideration, because combining information such as access and response rates can give us clear view of the state of the application.
F5 BIG-IP ASM offers an all-in-one solution for protecting applications and organizations from DDoS attacks by:
1 "'Tis the Season of DDoS," PandaLabs blog, December 2010
