Deploy F5 BIG-IP for Scality RING S3 clusters
This guide shows you how to deploy F5 BIG-IP Local Traffic Manager (LTM) in front of a Scality RING S3 cluster, presenting the entire cluster as a single, highly available S3 endpoint. BIG-IP load balances requests across the Scality RING nodes and runs custom HTTP/HTTPS health monitoring to route around failed or draining nodes, giving storage and network teams one performant front door to the cluster. As AI data delivery pushes more read and write traffic onto object storage than its built-in balancing was designed to absorb, that front door becomes the control point for keeping the path between storage and compute fast and resilient.
The procedure is validated on a virtual BIG-IP deployment in front of a 3-node Scality RING cluster, every manual step is also provided as well as the Ansible automation, so the build is repeatable across environments.
What this guide covers
  • Network configuration (Self IPs, VLANs)
  • Custom HTTP/HTTPS S3 health monitor
  • Pool definitions with Least Connections balancing
  • Optimized S3 traffic TCP profiles (CUBIC)
  • Virtual server setups with Source Address Translation
  • End-to-end validation using Warp benchmarking
  • Ansible automation
What you'll need
  • Administrative access to BIG-IP and Scality RING
  • Basic L2/L3 networking knowledge
High availability
Route around failed or draining Scality RING nodes easily.
Optimized performance
Custom TCP profiles and CUBIC congestion control for S3.
Repeatable automation
Automate deployments across environments using Ansible.
