This white paper examines the challenges and assesses the architectural alternatives for deploying next-generation, Diameter-based signaling.
Signaling systems have always been a vital component of telecom networks. However, with the formal separation of signaling and network bearer through the standardization of "out of band" Signaling System #7 (SS7) protocols in 1980s, a quantum leap was achieved. Not surprisingly, some 30 years later SS7 still remains an industry stalwart for TDM-based fixed and 2G mobile networks supporting Intelligent Network (IN) services.
But as IP networks become commonplace and TDM declines, new open standards based protocols capable of supporting IP services are required. As a result, we now see a renewed focus - a renaissance of sorts on the signaling plane-driven by this shift from TDM services to IP links for IP and Session Initiation Protocol (SIP) based services.
In this section of the white paper, we discuss in greater detail how Diameter nodes are evolving to fulfill next-gen networks signaling requirements and support the massive signaling volume triggered by today's smartphones and applications.
Given the unique attributes of IP networks, activity driving development of next-gen signaling systems started more than a decade ago and ultimately resulted in the completion of the Diameter specification: Internet Engineering Task Force (IETF) RFC 3588.
Since then, Diameter has steadily gained industry-wide acceptance in standards most notably in Release 7 and 8 of the 3rd Generation Partnership Project (3GPP) IP Multimedia Subsystem (IMS) specification. And given the extensive number of interfaces required in core and access IP networks, as per Figure 1, this means Diameter will only increase in relevance as IP networks deployments continue to ramp. Currently, there are approximately 50 3GPP and 3GPP2 defined interfaces that utilize Diameter signaling.
Long Term Evolution (LTE), in many respects, reflects a risk and reward scenario-substantial new revenue potential-but since services will require the implementation of the reference architecture points noted above (e.g., PCRF), consideration must be given to network design to ensure access to services, scaling sites and handling node failure.
Specifically, there are three distinct set of challenges that must be considered.
First, in order to scale Diameter endpoints, the typical approach is to simply add server computing resources on a site level (as per Figure 2). The downside of this approach is that each server requires its own link and address scheme for routing purposes.
Secondly, the highly distributed nature of next-generation networks must be also factored. In order to document the specific challenges this introduces we have defined two generic types of network sites in this white paper. They are:
The ABI group includes application servers and billing applic a tions. By nature, these tend to be major sites, heavily data-centric but fewer in number. Still, these sites must be geographically distributed to support IT redundancy requirements. As a result, a significant amount of signal exchange with potentially long distances may result.
In addition, the impact of CANI sites must be considered. As the name suggests, most core and access infrastructure - including EPC (SAE, MME, SGW, PDN and ePDG), PCRF, HSS and CSCFs-fall into this grouping.
Since these sites are even more numerous in nature to support redundancy and match subscriber penetration levels by market, an even greater potential exists to overcome signaling networks.
Still, regardless of whether a billing server or a PCRF failure occurs, in all cases both ABI and CANI sites must be able to recover from these failures in real time by rerouting signaling quests to alternate nodes that can be problematic using a peer-to-peer connection model.
A final area of apprehension is server resource optimization. Given the cost of both ABI and CANI server infrastructure, network operators must continue to ensure all servers are optimally utilized to reduce opex. This most common approach is to implement a load balancer to route signaling to underutilized servers, leveraging the same base software intelligence used for failure rerouting.
As a result of these concerns, standards development defined the creation of a standalone Diameter Routing Agent (DRA) in 3GPP to support routing Diameter signaling to several nodes such as CSCFs, PCRFs, HSS, and EPC (including MME).
Originally, this functionality was envisioned to be performed by the PCRF. And while this is still a valid implementation option, definition of the DRA is seen as representing a less complex approach for meeting the challenges. The DRA supports several agent capabilities:
3G has fundamentally changed the service mix for network operators, and 4G will undoubtedly have even greater impact as adoption of complex session-driven broadband services increase.
Therefore, network operators are increasingly concerned that the changes in traffic patterns originating from smart devices could create signaling "bottlenecks" on the Diameter interfaces discussed above, ultimately resulting in network-wide signaling failures.
The most recent example is that of NTT DoCoMo, which suffered a major network outage of approximately four hours on January 25, 2012, that was directly related to an abnormal peak in signaling traffic.
Consequently, interest in DRAs continues to grow. Essentially, by deploying a highly scalable DRA in a centralized architecture vs. peer-to-peer connections, as shown in Figure 3, it's possible to load balance signaling, perform session setup, handle failure rerouting and support centralized routing updates.
Harkening back to the era of SS7, the D-link STP interconnection model was defined to meet the same scalability and routing challenges that A-link connections between peer-to-peer nodes in the same network (intra-network) would encounter.
Conversely, signaling and routing challenges must be considered on not only an intra-network basis, but also an inter-network basis to support roaming.
Therefore, as illustrated in Figure 4, the GSM Association (GSMA) defined the Diameter Edge Agent (DEA) functionality based on DRA to support roaming. Like a DRA, the DEA supports the ability to act as a network proxy, or simply a relay. As a result, even though DEA and DRA have unique network topology profiles, since they both support similar functionality, some vendors have developed multipurpose products that support both functions.
Nevertheless, it's also important to note that Diameter products also must support a broad spectrum of 2G legacy protocol interworking to facilitate a graceful evolution path and roaming. For example, the Signaling Delivery Controller (SDC), a DRA and DEA compliant product from F5 Traffix Systems supports interworking with a full range of legacy protocol including Radius, LDAP, SS7 and 2G mobile GPRS Tunneling Protocol (GTP).
In this section of the white paper, we evaluate and quantify the value proposition of deploying a DRA to support a next-generation service such as voice over LTE (VoLTE).
Since LTE was designed as end-to-end, IP-based network, one of the main challenges identified early on was how to most effectively support legacy circuit-switched (CS) voice services.
While solutions such as falling back to 2G or 3G networks may be implemented in some conditions, in 2010 the telecom industry reached broad consensus that the GSMA VoLTE implementation that is based on IMS would be adopted to ensure seamless roaming. The implications from a signaling perspective are wide-ranging. This includes handling of the message exchange across several interfaces, including HSS and MMEs, PCRF to enforce policy control and CSCFs to establish and maintain session control.
There are several implementation options for handling VoLTE signaling. These options are:
Below, we analyze each of these options in turn.
This approach is unique from the other options in that it does not leverage a DRA in any way. Rather, as per Figure 5, it utilizes peer-to-peer Diameter signaling interfaces between CANI and ABI sites. Key implementation attributes and characteristics of this approach include:
In this scenario, as per Figure 6, DRAs are deployed to optimize CANI node signaling routing. ABI servers are not optimized. Key implementation attributes and characteristics of this approach include:
In this scenario, as per Figure 7, DRAs are deployed to optimize ABI node signaling routing. CAMI servers are not optimized.
In this scenario, as per Figure 8, DRAs are deployed both in ABI and CANI sites to optimize signaling routing.
Low Server-to-server methodology Medium CANI failures transparent to ABI Medium ABI failures transparent to CANI High CANI and ABI failures both transparent Low Difficult Medium CANI optimized; ABI not Medium ABI optimized; CANI not High CANI and ABI both optimized Low All topologies visible Medium CANI topology hidden; ABI visible Medium ABI topology hidden; CANI visible High CANI and ABI topologies both hidden Low Upgrade all node approach Medium CANI simplified; ABI servers unchanged Medium ABI simplified; CANI servers unchanged High CANI and ABI both simplified Low Medium Medium High
Evaluation Criteria
Peer-To-Peer
DRA–CANI
DRA–ABI
DRA–CANI & ABI
Failover
Signaling Transport Scalability
Security & Authentication
Administration & Routing
Overall Value Proposition
In many respects, the impacts of 4G all-IP-based services on next-gen signaling networks are only now starting to be understood. However, early experience has shown that these networks can be overcome by the amount of signaling resulting from smart devices and advanced services, even before the impact of roaming traffic is factored.
Furthermore, since 4G networks will need to be carefully engineered on an end-to-end basis to minimize investment, next-gen signaling networks by default will have to be highly scalable, reliable and cost-efficient. For that reason, although DRAs are not specifically required, given the scope of challenges currently identified, we believe DRAs have several advantages over a peer-to-peer approach.
In addition to providing a centralized point to support legacy network protocol interworking and roaming, the load balancing and routing capabilities ensure that next-gen signaling networks are cost efficient, scalable, reliable and aligned with the spirit of all IP networks to support extensible service models.
This Appendix provides an overview of F5 Traffix Systems ' Diameter based solution, the Signaling Delivery Controller.
The F5 Traffix SDC is a third-generation Diameter signaling solution that has unmatched product maturity in its three years as a commercial router and dozens of live deployments. As the market's only full Diameter routing solution combining 3GPP DRA, GSMA DEA and 3GPP IWF, the SDC platform goes far beyond industry standards' requirements. With unbeaten performance and ROI ratios of value/cost and capacity/footprint, it benefits operators' balance sheets as well as operational requirements. When operators deploy the Signaling Delivery Controller, they benefit from an “all-in-one platform” consisting of: Core Router with a DRA (Diameter Routing Agent) for failover management and efficiency, Edge Router with a DEA (Diameter Edge Agent) for roaming and interconnecting with security, Diameter Load Balancer for unlimited scalability enabling cost-effective growth, Diameter Gateway for seamless connectivity between all network elements, protocols, and interfaces to enable multi protocol routing and transformation, WideLens to benefit from network visibility for immediate identification and root cause analysis of network problems, capacity planning and providing KPIs to marketing, Network analytics for context-awareness and subscriber intelligence, Diameter testing tool for continual monitoring of network performance and operation.
Description
Benefits
This Heavy Reading white paper was commissioned by F5 Traffix Systems, but is based on independent research. The research and opinions expressed in this report are those of Heavy Reading, with the exception of the information in Appendix A provided by F5 Traffix Systems.
Jim Hodges has worked in telecommunications for more than 20 years, with experience in both marketing and technology roles. His primary areas of research coverage at Heavy Reading include softswitch, IMS, and application server architectures, protocols, environmental initiatives, subscriber data management and managed services.
Hodges joined Heavy Reading after nine years at Nortel Networks, where he tracked the VoIP and application server market landscape, most recently as a senior marketing manager. Other activities at Nortel included definition of media gateway network architectures and development of Wireless Intelligent Network (WIN) standards. Additional industry experience was gained with Bell Canada, where Hodges performed IN and SS7 planning, numbering administration, and definition of regulatory-based interconnection models.
Hodges is based in Ottawa and can be reached at hodges@heavyreading.com
