A Different Kind of Multiverse: Multi-Model and Multimodal Integration
F5 ADSP | January 30, 2024
Safely and securely integrating multimodal AI models and/or multiple models into existing digital infrastructures is emerging as a significant issue in conversations about why, when, and how to deploy generative AI (GenAI), including large language models (LLMs), across the enterprise. While many organizations have already deployed at least one GenAI model—nearly 15% in one recent survey—considerably more have put off deployment for three to 12 months, with the balance continuing to debate whether to bring LLMs into their systems at all.
The benefits of having even a single unimodal language model in place—ChatGPT-3.5 or others, for example—can bring enormous increases to efficiency and productivity when used for text-based tasks, such as content generation, summarization, analysis, and translation. However, bringing in multiple models or models that use or create non-text content, is the creative version of a “force multiplier” and requires a different strategy.
Multimodal? Multi-Model?
The scenarios for an organization that deploys multiple AI models vary widely. While some organizations might want to leverage the capabilities of more than one large public LLM, for instance using both BERT and Gemini rather than one or the other, there are many more options available to them.
In little over a year since ChatGPT launched, many new model types have emerged, including:
  • Targeted models focused on specific markets, such as finance, law, pharma, and retail
  • Models embedded in software-as-a-service (SaaS) applications
  • Internal models built in-house and trained on proprietary data
  • Retrieval-augmented generation (RAG) models, which are extensions added to the large public models to provide access to more recent information
  • Small language models (SMLs) that require considerably less compute power and, in some cases, can run on a personal computer
It has become a common understanding among AI industry insiders that large enterprises will be deploying a lot of models, if not hundreds by some estimates, across their organizations in the next few years, as models become easier and cheaper to create, train, and maintain. Many of those newly deployed models will likely be multimodal (such as later versions of ChatGPT and others), which means they can ingest queries in various formats, such as voice, text, audio, images, video, code, etc., and produce content in the same or a different format. For instance, a user provides vocal instructions to the model to produce content in a specific format, such as a graph, image, or audio clip.
Risk Multiplied
The benefits of integrating multiple models and multimodal models into an organizational structure are tremendous and continue to expand into new use cases at the developer, analyst, general user, and customer levels. The risks, however, cannot be overstated and must be addressed before integration.
Adding any AI tools to an organization’s digital infrastructure immediately expands the attack surface, and adding multimodal models can complicate that further. A multimodal model’s architecture includes numerous entry points, which become vulnerable to exploitation by attackers.
Likewise, focusing on securing some modalities in a model or AI system while overlooking others can create blind spots in the security posture of a multimodal system. Attackers can always be counted on to exploit the weakest link, whether that means entering a system through an unsecured portal or slipping malicious code into the model’s response.
As regulations have begun to come into effect across the globe, compliance, especially around ensuring data privacy, has become a significant pain point for AI security teams. The data that must be protected no longer consists of just text records, but digital images, audio files, videos, scans, fingerprints, x-rays, MRIs, voice prints used as verbal confirmation; as well as highly specialized scientific content.
All of this data could be exposed in a data breach, but could also be manipulated and sold for malicious uses, including the creation of deep fakes. Integrating various modalities into existing digital infrastructures also presents challenges such as interoperability issues, when different technologies and protocols must work together seamlessly and one misconfiguration or vulnerability can compromise the entire system’s security.
This can be resource-intensive to fix, can potentially introduce model performance problems, such as latency, and could require additional hardware, which, if not managed correctly, may itself introduce security vulnerabilities.
AI Security Solutions
The lack of standardized practices around the subject of AI use makes it even more challenging to ensure consistent security in user environments. However, solutions are emerging in the AI security space to make deployments more secure and, therefore, more attractive to risk-averse organizations.
Our model-agnostic GenAI security solutions are the first of their kind to provide 360° protection to AI systems. A “weightless” trust and control layer positioned outside, but immediately adjacent to the infrastructure, our runtime security solutions shield the organization from threats buried in AI model responses and other external threats. It ensures prompts that contain damaging instructions or private information do not leave the system, and does so all without introducing latency into the process.
Administrators can use policy-based access controls to authorize or block access to models by individual user and by teams, which:
  • Allows cost-monitoring by limiting who can access the models
  • Supports deployment of rate limits to ensure that Model Denial of Service (DoS) attacks do not succeed in slowing or shutting down the system
  • Enables customizable scanner criteria to be set according to the needs of each team, enabling greater adherence to company acceptable use policies
Our solution also provides security teams full observability into and across all AI tools on the system, allowing them to understand how the models are being used and ensuring they are not being misused or abused. Similarly, administrators have visibility into user and group usage patterns and practices. Each model interaction is tracked and retained for review and analysis, providing insights into user behavior. The prompt history can be purged, either manually or automatically; administrators also have the option of not retaining any of the prompts for review. Interactive dashboards provide a wide variety of detailed usage data about the models, individual users, and groups at admin-determined time spans.
The integration of multiple and multimodal GenAI models into an existing digital infrastructure presents opportunities, risks, and challenges in roughly equal measure. Contemporaneously implementing cyber and AI security practices presents the best option for the organization to engage in operations as usual while knowing its people, property, and processes are safe from AI-driven risk.
Click here to request a demo.
How are customers using the F5 AI Security Platform?
F5 ADSP | 10/22/2026
See why customers are turning to the F5 AI Security Platform for strong, out-of-the-box protection plus the customization they need to meet their specific security needs.
Cloud-native modernization for the AI and 5G/6G era
F5 ADSP | 10/07/2026
See why 5G/6G, Kubernetes maturity, and AI are accelerating cloud-native modernization, and how F5 BIG-IP Cloud-Native Edition improves efficiency.
Who can you trust in the age of AI agents?
F5 ADSP | 09/15/2026
New features for F5 Distributed Cloud Bot Defense enable organizations to distinguish between trusted and fraudulent AI traffic.
From dashboard fatigue to operational excellence: Why XOps needs F5 Insight for ADSP
F5 ADSP | 03/26/2026
Learn how F5 Insight for ADSP lays the visibility foundation for XOps—turning fragmented signals across applications and infrastructure into actionable intelligence.
Govern your AI present and anticipate your AI future
F5 ADSP | 12/18/2025
Learn from our field CISO, Chuck Herrin, how to prepare for the new challenge of securing AI models and agents.
F5 recognized as one of the Emerging Visionaries in the Emerging Market Quadrant of the 2025 Gartner® Innovation Guide for Generative AI Engineering
F5 ADSP | 11/25/2025
We’re excited to share that F5 has been recognized in 2025 Gartner Emerging Market Quadrant(eMQ) for Generative AI Engineering.
