99.92% availability, significantly higher than their previous legacy solution
Massive reduction in time and cost of app integration with Commerce Cloud, requiring a few hours/app at no additional cost, versus weeks of work and thousands of dollars
Simplified access to SAML applications, with 35 apps in production
Required a strong set of APIs to provide partners with secure access to services
Need for a flexible and scalable sign-on and provisioning options for desktop and mobile users
Compatibility with modern protocols such as SAML and OAuth
High availability and reliability
This global technology company has pushed the boundaries of technology for almost 100 years. Pitney Bowes continues to do so by using Okta + F5 Networks to help their over 2.8 million users access new digital services through the Pitney Bowes’ Commerce Cloud.
In 2016, Pitney Bowes launched a complete e-commerce solution that streamlined everything from international payments to sales promotions. The Pitney Bowes Commerce Cloud offers a suite of global e-commerce capabilities delivered to customers and partners via mobile and the web. From the very beginning, Pitney Bowes knew that they needed best-of-breed identity solutions to keep their Commerce Cloud secure for its millions of users.
The migration to the Commerce Cloud was not easy: Pitney Bowes’ IT environment contained multiple legacy and cloud-based apps, each with its own internal federations. Access to each of these had to be streamlined in order to perform the migration without causing outages.
“Outages translate to lost capabilities and lost access for customers,” says Henry Rogando, Principal Software Architect at Pitney Bowes. “As such, it was important to find a highly reliable mechanism that could migrate these applications without introducing new issues.” Essentially, Pitney Bowes needed to simplify the worflow by running cloud-based and legacy apps through Okta in a safe and reliable way.
To further scale and secure customer access to Commerce Cloud, Pitney Bowes turned to Okta’s integration with F5 Networks. Pitney Bowes was already using F5 Networks for load balancing via the BIG-IP Local Traffic Manager (LTM). By adding the BIG-IP Access Policy Manager (APM) module, Pitney Bowes leveraged the Okta + F5 Networks integration to replace its legacy access management gateway. Now Okta worked as the authentication point, and F5 Networks helped with the reverse proxy requirements. Okta and F5 Networks provided a streamlined solution for access to both cloud and on-prem applications.
With single sign-on (SSO) enabled alongside the new integration, Pitney Bowes’ customers are able to navigate between all of the apps, cloud-based or on-prem, without experiencing any kind of disruption.
Thanks to the Okta + F5 Networks integration, Pitney Bowes successfully migrated their entire portal and launched a robust e-commerce offering. And the best part? They pulled it all off without disrupting any of their 2.8 million users.
To view the full case study, click here.
We now have a SAML single sign-on protocol established between Okta and F5. F5 handles the access management and authorization and translates it into the headers that are needed by the application.
